4. Robotic Electrical Interface ​
4.1 End Flange ​
The End-effector flange has 6 M6 threaded holes and one Ф6 positioning hole, where the end-effector of two different sizes can be mounted.
If the effector does not have a positioning hole, the orientation of the end-effector must be documented in a file format, to avoid errors and unexpected results when re-installing the end-effector. The end-effector flange referenced ISO 9409-1-50-4-M6 standard.
4.2 Tool IO ​
At the tool side of the robotic arm, there is an avionic socket 8-pin female industrial connector. This connector provides power and control signals for the grippers and sensors used on a particular robotic arm tool. Please refer to the figure below:
There are 8 pins inside the cable with different colors, each color represents different functions, please refer to the following table:
PINColorSignalPINColorSignal
1Brown+24V (Power)5BlackTool Output 0 (TO0)
2White0V (GND)6GreyTool Output 1 (TO1)
3GreenRS485-A/Analog Input 0 (TAI0)7RedTool Input 0 (TI0)
4YellowRS485-B/Analog Input 0 (TAI1)8PurpleTool Input 1 (TI1)
Electrical Specifications:
ParameterMin. ValueTypical ValueMax. ValueUnit
Supply Voltage in 24V Mode202430V
Supply Current--1000mA
NOTE
It is strongly recommended to use a protection diode for inductive loads.
DANGER
Make sure that the connecting tool and the gripper do not cause any danger when the power is cut, such as dropping of the work-piece from the tool.
4.2.1 Tool Digital Input(TI) ​
The digital input is already equipped with a pull-down resistor. This means that the reading of the floating input is always low.
ParameterMinTypicalMaxUnit
Input Voltage-0.5-30V
Logic Low Voltage--1.0V
Logic High Voltage1.6--V
Input Resistance-47k-Ω
The following figure shows the connection with the simple switch.
4.2.2 Tool Digital Output(TO) ​
The digital output is implemented in the form of NPN with an open collector (OC). When the digital output is activated, the corresponding connector will be driven to GND. When the digital output is disabled, the corresponding connector will be open (open collector/open drain).
Open-circuit Voltage-0.5-30V
Voltage when sinking 50mA-0.050.2V
Sink Current0-100mA
Current through GND0-100mA
CAUTION
There is no current protection on the digital output of the tool, which can cause permanent damage if the specified value exceeded.
The following example illustrates how to use the digital output. As the internal output is an open collector, the resistor should be connected to the power supply according to the load. The size and power of the resistor depend on the specific use.
NOTE It is highly recommended to use a protection diode for inductive loads as shown below.
4.2.3 Tool Analog Input(TAI) ​
The tool analog input is a non-differential input.
Input Voltage in Voltage Mode-0.5-3.3V
Resolution-12-Bit
Input Current in Current Mode---mA
Pull-down Resistors in the 4mA to 20mA Current Range--165Ω
Resolution-12-Bit
CAUTION
  1. In the current/voltage mode, the analog input does not provide over-voltage protection. Exceeding the limits in the electrical code may result in permanent damage to the input port.
  2. In current mode, the pull-down resistance depends on the range of the input current.
The following figures show how the analog sensor can be connected to a non-differential output.
  • Voltage Mode
  • Current Mode
The following figures show how the analog sensor is connected to the differential output. Connect the negative output to GND (0V), and it can work like a non-differential sensor.
  • Voltage Mode
  • Current Mode
4.2.4 Tool RS485 ​
The Tool side provide an RS485 interface, use can communicate it with third-party devices that supports RS485.
The id of our end tool is 9.
PIN Connection:
  1. PIN3: RS485-A
  2. PIN4: RS485-B
  3. PIN1: 24V
  4. PIN2: GND
