5. Maintenance and Inspection
- Long-term placement If the robotic arm is not used for a long time (≥3 months), you need to power on the robotic arm for 6 hours every 3 months to charge the built-in battery of the robotic arm. When powering on the robotic arm, please release the emergency stop button on the control box, and the robotic arm does not need to be enabled.
- Clean
After the robotic arm is used for a long time, there may be dirt or grease on the carbon fiber shell (in rare cases, a small amount of grease can be seen at the joints, which will not affect the normal use or life of the joints). You can use 95% alcohol or 70% isopropanol to wipe the carbon fiber surface for cleaning.
Note
When cleaning the carbon fiber surface, be careful not to let the liquid penetrate the joints.
