9. Technical Specifications ​
Lite6
Robot TypeLite6
Cartesian RangeX: ±440mm; Y: ±440mm; Z: -165~683.5mm; Roll/Pitch/Yaw: ±180°
Weight(robotic only)8KG
Maximum Payload600g
Maximum Joint Speed180°/s
Maximum Speed of End-Effector500mm/s
Repeatability±0.5mm
Ambient Temperature Range0-50℃
Power ConsumptionTypical 150W, 300W Power is recommended.
Input Power Supply24V DC, 14.66A
ISO Class Cleanroom5
Mounting WayAny Direction
MaterialsAluminium, Carbon Fiber
Footprint130×140 mm
End FlangeDIN ISO 9409-1-A50/63(M6*6)
Robotic Arm Communication ProtocolPrivate TCP(custom)
End Effector Communication ProtocolModbus RTU
ProgrammingUFACTORY Studio, Python/C++/ROS
Joint Rotation Direction
Gripper Lite (LG1000)
Stroke16mm
Gripping Force5N
Weight290g
communication ModeI/O
Lifespan>6000H
Vacuum Gripper Lite(LS1001)
Vacuum Level-40kPa
Weight190g
Communication ModeI/O
FeedbackPick-Up Detection
Lifespan>6000H
